хаби AVM лебидки проставки
Повідомлення Matador » П'ят липня 25, 2014 18:48
Продам
067-270-60-57
093-759-61-59
AVM 401 Jeep: Willys, CJ Mahindra Jeepster Gladiator 10 6 185y.o.
AVM 402 Jeep CJ, Engesa, Umm Alter 27 6 195y.o.
AVM 403 Daihatsu Rocky, Rugger 26 5 185y.o.
AVM 410 Uaz Gaz 10 6 185y.o.
AVM 410HP Uaz Gaz 10 6 225y.o.
AVM 413 4Runner, HiLux, Previa HiLux HiLux Sr5 VW Taro 26 6 185y.o.
AVM 415 ARO - model M249 (od 1978) 10 10 315y.o.
AVM 421 Toyota Hilux, HZJ 80, FZJ 70-75 30 6 185y.o.
AVM 421HP Toyota Hilux, HZJ 80, FZJ 70-76 30 6 225y.o.
AVM 721 Toyota Hilux, HZJ 80, FZJ 70-77 30 6 280y.o.
AVM 423 Nissan K160 K260 "Hiszpan" 29 6 185y.o.
AVM 423HP Nissan K160 K260 "Hiszpan" 29 6 225y.o.
AVM 723 Nissan K160 K260 "Hiszpan" 29 6 280y.o.
AVM 428 Mitshubishi L200, Pajero 28 6 (8mm) 185y.o.
AVM 429 Terrano I, Nissan pick-up, King Cab, Pathfinder 27 6 185y.o.
AVM 432 Isuzu Trooper do 1986 24 6 185y.o.
AVM 433 Trooper II Rodeo Pickup D-Max Campo Monterey 17 6 190y.o.
AVM 438 Suzuki SJ, Samurai, Vitara , Grand Vitara, Jimny 26 6 185y.o.
AVM 438HP Suzuki SJ, Samurai, Vitara , Grand Vitara, Jimny 26 6 210y.o.
AVM 738 Suzuki SJ, Samurai, Vitara , Grand Vitara, Jimny 26 6 290y.o.
AVM 440 Daihatsu Feroza, Four Track, Rocky цена 24 5 185y.o.
AVM 443 Galloper Mitsubishi Triton L200 Pajero Montero 28 6 (10mm) 185y.o.
AVM 443HP Galloper Mitsubishi Triton L200 Pajero Montero 28 6 (10mm) 225y.o.
AVM 445 Nissan Patrol Y60, Y61, PickUp TATA Sumo 31 6 185y.o.
AVM 445HP Nissan Patrol Y60, Y61, PickUp TATA Sumo 31 6 225y.o.
AVM 745 Nissan Patrol Y60, Y61, PickUp TATA Sumo 31 6 280y.o.
AVM 448 KIA / ASIA MOTOR: ASIA Rocsta 10 6 185y.o.
AVM 449 Opel Frontera, Isuzu Trooper 17 6 190y.o.
AVM 449HP Opel Frontera, Isuzu Trooper 17 6 225y.o.
AVM 450 SsangYong Musso, Korando, Rexton 28 6 185y.o.
AVM 450HP SsangYong Musso, Korando, Rexton 28 6 225y.o.
AVM 452 Nissan Terrano II, D21, Ford Maverick 27 6 185y.o.
AVM 452HP Nissan Terrano II, D21, Ford Maverick 27 6 225y.o.
AVM 453 Ford Ranger 1999-2001 26 6 210y.o.
AVM 456 Toyota Hilux 167/169 (08.1997->) Hilux 172 (11.1997->) 26 6 210y.o.
AVM 457 Suzuki Jimny od 1999r 26 6 200y.o.
AVM 457HP Suzuki Jimny od 1999r 26 6 225y.o.
AVM 460K Kia Sportage 94-97 mech, Retona, Frontier 26 6 210y.o.
AVM 460 Kia Sportage 97-> podciś, Retona, Frontier 26 6 185y.o.
AVM 460HP Toyota Prado, KZJ71, Land Cruiser II 26 6 225y.o.
AVM 461 Nissan D22 28 6 185y.o.
AVM 463 Toyota Prado, KZJ71, Land Cruiser II 30 6 270y.o.
AVM 463HP Toyota Prado, KZJ71, Land Cruiser II 30 6 340y.o.
AVM 465 Ford Ranger Explorer 90-97 27 5 250y.o.
AVM 466 Daihatsu Rocky F73/78 26 6 185y.o.
AVM автоматические
AVM 901 Jeep WiLLYS 525y.o.
AVM 910 УАЗ 565y.o.
AVM 913 Toyota 4Runner, HiLux, Previa HiLux HiLux Sr5 VW Taro 535y.o.
AVM 918 Ford 605y.o.
AVM 921 Toyota Toyota Hilux, HZJ 80, FZJ 70-75 525y.o.
AVM 938 Suzuki SJ, Samurai, Vitara , Grand Vitara, Jimny 560y.o.
AVM 943 Galloper Mitsubishi Triton L200 Pajero Montero 28 6 (10mm) 560y.o.
AVM 960 Kia 97-> . Sportage Grand Sportage Retona Frontier 26 6 550y.o.
AVM 961 Nissan PickUp, Navara D21, D22, Pathfinder 26 6
AVM 1050 SsangYong Musso, Korando, Rexton 28 6 385y.o.
Лебедка Dragon Winch DWM 8000HD Maverick-375 дол
Лебедка Dragon Winch Winch DWM 10000HD Maverick-395дол
Лебедка Dragon winch DWM12000 maverick -415 дол
Лебедка Dragon winch DWM13000 maverick -490 дол
Лебедка Dragon winch DWH 9000HD-740 дол
Лебедка Dragon winch DWH 12000HD- 12v-630y.o. 24V-650y.o.
Лебедка Dragon winch DWH 12000HD V 2 SPEED-710 дол
Лебедки XTR
" Лебедка XTR 12000 LBS [5443kg] 12В/24В
-Применение: солидная лебедка с очень широким спектором применения - от больших внедорожников до эвакуаторов -Тяговое усилие: 12000лб (5443кг) -Двигатель:6,6 л.с./4,8KW -Редукция: 265 : 1 -Редуктор: 3 ступенчатый планетарный -Тормоз: Усиленный, автоматический на двигателе -Размер барабана: Диаметр 64 мм длина 224мм -Трос : металлический 28м/9,0мм -Направляющий троса: Ролики -Монтажные отверстия: 254x114,3 mm -Размеры: (LxWxH) (540x155x160 ) -Вес: 36 кг -Система управления: Проводной пульт 3,7м + без проводной пульт 50 метров -Гарантия: 2 года"
445y.o.
-Применение: Безотказная лебедка с широким спектром применения. С легким и прочным синтетическим тросом -Тяговое усилие: 12000лб (5443кг) -Двигатель:6,6 л.с./4,8KW -Редукция: 265 : 1 -Редуктор: 3 ступенчатый планетарный -Тормоз: Усиленный, автоматический на двигателе -Размер барабана: Диаметр 64 мм длина 224мм -Трос : синтетический 26м/10мм -Направляющий троса:Алюминевий клюз -Монтажные отверстия: 254x114,3 mm -Размеры: (LxWxH) (540x155x160 ) -Вес: 29 кг -Система управления: Проводной пульт 3,7м + без проводной пульт 50 метров -Гарантия: 2 года"
500y.o.
"Лебедка XTR 13500 LBS [6130kg] 12В/24В
-Применение: Прочная лебедка с усиленными основаниями и с очень широким спектором применения - от больших внедорожников до эвакуаторов -Тяговое усилие: 13500лб (6130кг) -Двигатель:6,6 л.с./4,8KW -Редукция: 265 : 1 -Редуктор: 3 ступенчатый планетарный -Тормоз: Усиленный, автоматический на двигателе -Размер барабана: Диаметр 64 мм длина 224мм -Трос : металлический 28м/9,0мм -Направляющий троса: Ролики -Монтажные отверстия: 254x114,3 mm -Размеры: (LxWxH) (574x199x241 ) -Вес: 40 кг -Система управления: Проводной пульт 3,7м + без проводной пульт 50 метров -Гарантия: 2 года"
475y.o.
" Лебедка XTR 15000 LBS [6800kg] 12В/24В
-Применение: Очень сильная лебедка для повышенных требований. -Тяговое усилие: 15000лб (6800кг) -Двигатель:6,6 л.с./4,8KW -Редукция: 364 : 1 -Редуктор: 3 ступенчатый планетарный -Тормоз: Усиленный, автоматический на двигателе -Размер барабана: Диаметр 64 мм длина 224мм -Трос : металлический 28м/11мм -Направляющий троса: Ролики -Монтажные отверстия: 254x114,3 mm -Размеры: (LxWxH) (569x215x225 ) -Вес: 65 кг -Система управления: Проводной пульт 3,7м + без проводной пульт 50 метров -Гарантия: 2 года"
565y.o.
" Лебедка XTR 17000 LBS [7718kg] 12В/24В
-Применение: Очень сильная лебедка для повышенных требований. -Тяговое усилие: 17000лб (7718кг) -Двигатель:7,2 л.с./4,8KW -Редукция: 364 : 1 -Редуктор: 3 ступенчатый планетарный -Тормоз: Усиленный, автоматический на двигателе -Размер барабана: Диаметр 64 мм длина 224мм -Трос : металлический 28м/11мм -Направляющий троса: Ролики -Монтажные отверстия: 254x114,3 mm -Размеры: (LxWxH) (569x215x225 ) -Вес: 65 кг -Система управления: Проводной пульт 3,7м + без проводной пульт 50 метров -Гарантия: 2 года"
650y.o.
Проставки
1.
6x139,7
12x1,25
50mm
С шпильками и гайками
60y.o.
2.
6x139,7
12x1,25 12x1,5
40mm 40mm
С шпильками и гайками С шпильками и гайками
50y.o. 50y.o.
3.
6x139,7
12x1,25 12x1,5
30mm
30mm
50y.o. 50y.o.
4.
6x139,7
5mm
10y.o.
5.
6x139,7 i 5x139,7
6,5mm
центр 107mm
10y.o.
prostavka new1
6.
5x139,7
12x1,25
30mm
50mm
50y.o.
12x1,5
30mm
50y.o.
12x1,25
50mm
60y.o.
7.
5x139,7
5mm
10y.o.
8.
5x165,1
16x1,5
30mm
56y.o.
9.
5x120.62
Land Rover Discovery II
Range Rover P38
не подходит для VW AMAROC 5x120
14x1,5
30mm
50y.o.
10.
5x114,3 xTrail
Totota Rav4
Jeep XJ, ZJ, Wrangler TJ,
12x1,25
30mm
50y.o.
12x1,5
50y.o.
1/2
50y.o.
1/2
С центрирующим кольцом
60y.o.
11.
5x127
Jeep
1/2
30mm
С шпильками и гайками С центрирующим кольцом
12.
5x127
Jeep
1/2
30mm
13
6x114,3
Nissan Navara
12x1,25
30mm
50y.o.
14.
5x130
Mercedes G
12x1,5
30mm
50y.o.
12x1,5
40mm
14x1,5
30mm
15.
6x114,3/6x139,7
12x1,25
30mm
проставка плавающея, на ступице 6x114,3 на диску 6x139,7
50y.o.
16.
5x165,1/5x120
14x1,5
30mm
проставка плавающея, на ступице 5x165,1 на диску 5x120
85y.o.
17.
5x150
14x1,5
30mm
60y.o.
Востаннє редагувалось Matador в П'ят квітня 24, 2015 20:20, всього редагувалось 1 раз.
Matador
Повідомлення: 185
Re: хаби AVM лебидки проставки
Повідомлення Matador » П'ят жовтня 10, 2014 1:00
Лебедка Escape 12000 LBS [5443kg] 12В
-Двигатель:6,6 л.с./4,2KW
-Редукция: 265 : 1
-Тормоз: автоматический
-Размер барабана: Диаметр 63,5 мм длина 224мм
-Трос : металлический 28м/9,5мм
-Размеры: (LxWxH) (530x160x218 )
-Вес: 40 кг
-Гарантия: 2 года
цена-420 дол
Лебедка Escape 12000 LBS [5443kg] 12В c тросом синтетическим 26м
-Редукция: 265 : 1
-Направляющий троса: Клюз
-Вес: 30 кг
-Система управления: Проводной пульт 3,7м + безпроводной пульт 50 метров
-Гарантия: 2 года
цена-600 дол
Matador
Повідомлення: 185
Повідомлення Matador » Суб лютого 28, 2015 14:38
актуально!
Matador
Повідомлення: 185
Повідомлення Matador » П'ят квітня 24, 2015 20:20
в продажі
Matador
Повідомлення: 185
Повідомлення Matador » П'ят жовтня 16, 2015 23:25
актуально
Matador
Повідомлення: 185
